If I create a DT in an Assembly will it be able to pick up dimensions of:
Sketches - In the assembly
Sketches - Inside of PARTS inserted in the assembly
Sketches - Inside of PARTS inserted into a Sub-Assembly which is Inserted into the Assembly
Unfortunately you are kind of limited as to what you can and cannot do at the assembly level. With 2011 however there are global variables and equation importing to help with a configurator set up.
