Background:
I have a top-level assy. w/ 15 sub-assy. Everything functions as designed mechanically. I bring in one more sub-assy, to top level. I create mates on front plane, right plane looks good then make final coincident mate between two sub-assy and I get over define mate. This is not just one warning but in five of the sub-aasy, so a total of a dozen warning. The warnings could be coincident, parallel, concentric, angle mates.
Need /Tried:
I need this last coincident mate between the two sub-assy so they can move (rotate) together. I have checked all previous mates in sub-assy and top level and all looks well. I have tried an Advanced Mate, (Symmetric) w/ same results as above.
At this point I’m not sure what else to try or to check, any ideas?
Happy Thanksgiving
Check or Make sure if there is any fixed assembly that might needs to be converted or solved as flexible in the top level assembly.
