Hi all,
When in a part / assembly if I use the measure tool a fly out box appears with info in it.
What I would like to see is when in an assembly if I highlight a part either in the model or feature tree and run a macro
then a fly out box similar to the measure tool fly out would appear showing a list of the custom properties of the selected part.
Is there a macro out there what does this that anyone would be willing to share.
Or is there a better way to get this custom part info when in an assembly.
Mark (SolidWorks 2011)
Hi Mark,
Here's a different solution
How about inserting a BOM into the assembly, you can have it in the same window or a separate one as I have shown.
When you select an item in the assembly the corresponding line is highlighted in the BOM, you will also have the option to add details as you go
