I have added my solidworks models to a folder, they all have the .sldprt extension. I then open up the CW library to add them. I use Tools/Import Parts from Folder then browse to where I have stored them.
When I select the path, I select OK and the the Select Component Orientation screen pops up. I then select the orientation I need and select OK. Now I receive a message that reads "No Solidworks components were found in the specified folder. Index was outside the bounds of the array." I don't know what that message is referring to. I close out this message and then close the library. I opened up the library again and see the parts I just tried to load into my component library. This does not make sense since the pop up message stated there were no solidworks components. Has anyone experienced this.
Very frustrating
HS
Hello Harry,
The message you are seeing "No SolidWorks components were found in the specified folder" should only pop up when that is the case and the “an index being outside of the array” is a crash but it seems like you are seeing a mixed set of results here as it sounds as if you don't crash but also do get your components imported correctly - would that be accurate to assume?
What I'd like to get is a clearer idea of the circumstances so may I ask that you record a video of the workflow and attach it to a post?
The import of components for SW2011 has changed substantially so I'm assuming at this point that you're using circa SW2010? If you are experiencing any blocking issues, please report these to your reseller and ask that the SR be processed as high priority and it will make it's way to me in the system.
Best Regards,
Anthony Read
