I upgraded to 2011 SP0 a few weeks ago. I'm noticing that about 40% of time, when I open or start a new part, assembly, or drawing I get extremely poor performance and visual lag. The solution so far has been to simply close the file and re-open it, but that is getting annoying. Has anyone experienced similar issues?
I normally have great performance when things work well.
FYI:
I am running XP 32 bit with an intel core 2 duo, and an ATI FireGL V3600 gpu driver version 8.583.0.0
I'm going to try to update the driver to see if this solves the problem, but I think that my normal performance 60% of the time might rule that out.
Charlie,
When you upgraded,
Do you still have your old version on the computer?
If you don't did you clean out your registry from the old install?
How much memory does your system have?
