Are you working with scanned data? The only way to remove
edges between a bunch of surfaces in SolidWorks is to remodel it.
You might be able to remove a few edges by deleting some faces and
using the Fill surface to replace them, but this will be tedious
and inaccurate. The problem is probably that the underlying nurbs
surfaces are broken up. SW does not have a function to do replace
multiple nurbes bodis with a single body, although the function
exists in other software.
I had a IGES file of surfaces. I opened this file in SW. I knitted these surfaces build a solid with these. Not, I see where every surfaces were on the solid. I would like to not see them... How can I?
Pete
Thanks, but if I need to be in shaded mode with edge... to see well some other parts???
Ken Maren
Muderlak Design
www.muderlakdesign.com
RMB on this part, component display, shaded.
If not in assembly, I don't know
Rob
