The part in question is thin rectangular plate with a hole through its center. An outward-acting force (tension) is applied to one of the faces, and the opposite face is fixed. However when I mesh and run the simulation SW is unable to complete the simulation. Solid Edge can perform this with this simulation tools. Any ideas how I can get this loading scenario to work with SW? A picture of the simulation set-up is attached.
2010 Student Edition
Thanks in advance
There can be several reasons behind it. Are you trying to use SimulationXpress or SimulationWorks. Can you upload the part (with boundary conditions set) here to check.
I did a quick test using SW SimulationXpress and it worked fine.
