...Is it possible to retrieve the 2009 version?
Thanks in advance,
Matt
Thanks in advance,
Matt
Thanks for all the replies.
@ Scott/Andy/Deepak:
It would be great if I could keep both versions of SW, if not, then I can work on 2010 only, as I have some projects already completed using 2010, and I don't wish to loose them, or not be able to edit them.
The reason for wanting 2009 back is that the work I'm doing now is required to be in the 2009 format, and I'm not completely sure if the 2010 version is different in that aspect (guess I should've asked that first), or whether or not it is accepted.
Matt,
Yes, you can uninstall 2010, but you have to clean out the registry completely of all Solidworks
to do this. I have a file if you need it that shows you how to clean out the registry.
