Hello everyone,
Just a quickie in regards to routing and configurations. If I have a routing assembly with several spools within it, if I make configurations of the assembly so each configuration is a different spool, suppressing all items not associated with that spool, will this cause problems with the assembly? I have tried a couple of times sometimes with success other times with none. The cause of the cherry seems to be with tee's. After I have separated all of the spools into configurations where ever there is a Tee the problem box comes up saying "Error: Missing Elbow"
Cheers
Sammy
