My problem is that when I add a draft angle and extrude a sketch using "offset from surface" the draft starts at the sketch instead of the surface. If the surface is curved then the projection is not the correct size or in proportion at its base due to the draft angles. Is it possible for the draft to start at the base of the projection and not the sketch. This is my first post. Sorry if this is answered already. Thanks for any help.
Brian,
I'm still not sure about exactly what you are trying to do, but I think you need to extrude your feature without the draft, then use a Parting Line Draft, picking the edges on your curved face and the plane or face from the sketch for the direction.
Jerry Steiger
