How do you change the background in an exported/save as dwg/dxf drawing to white with black lines/dimensions/text instead of the default black background and dark grey part with white title block? I apologize if this has already been covered. I did a search and brought up two unrelated results.
Tim
Tim,
Check under these settings.
Tools>Options>System Options>Colors
You can also create a template and use that to incorporate these dxf files into and use this command
in the template and after the dxf is imported to change specific lines.
