hi all
my name is amir levy and i am an aerospace engineer working in israel.
i have recently started design on a machine with some mechanical mates and have encountered a strange problem.
while using the "rack and pinion" mate i noticed that after mating, the parts dont move as intended.
instead what happens is the following: when i rotate the pinion the rack is going back and forth instead of just one direction. and the same happens when i
slide the rack (the pinion rotates back and forth).
does anyone has any idea what could be causing this?
thanks in advance
Welcome to SW forums Amir.
Here are some of the Gabi's posts on Rack and Pinion which might be helpful.
Animating an arbor press with SolidWorks Motion
Is there a bug in Motion?
A few thoughts on my Motion issue
