Wanted to make sure that I wasn't going crazy.
I've got a appearance attached to several bodies. Going in to edit the appearance and remove two of the bodies and clicking "ok" causes the appearance to double in the "Appearance Manager". Then I have to then RMB click on that and remove it. So it seems like the program takes it out of the original one and just makes a duplicate of it again since it was removed from the selection box.
If anyone can confirm this before it's submitted, it'd be much appreciated.
Regards,
Arty
Which version and SP of SW?
Does this happen with all appearances?
Can you post an image of what you are seeing?
