I am working on an HP z400 workstation that has a Quadro FX1800 GPU. I noticed that Realview dosn't work anymore, it is grey and I can't activate it.
Can someone help me with this?
Best Regards,
Dragos
Best Regards,
Dragos
Close all solidworks documents, go to system options, performance, and check that use software open gl hasnt been checked by mistake.
It is checked marked but it is grey and I can't uncheck it. I don't know why it is like this because I didn't mde any changes to the settings.
So the question is half aswered, only I someone knows how to uncheck it. Enclosed a print creen of the performance window.
I forgot to mention that I use SW 2009 and Win XP 64 bit, maybe this helps for an answer.
I did as you said and I closed all other files and the checkmark was still grey, but after a closed and reopen of the SW program it seems the OpenGL magicaly was unchecked. This is really strange.
Thanks for the answer. Now if this problem comes up again I know where to look first.
I gave the CORRECT ANSWER to some else by mistake, can it be undone? I wanted to press Greg Hynd's answer. Sorry
Close all open files in the SolidWorks and then you should be able to un-check it
