i am taking a class called solid modeling, we are using solid works and it is a very powerful tool!!! i am creating a 8 pin dip socket i have everything done except the chamfers will not mirror, or linear pattern. The sweep i made works patterns and mirrors perfectly why would the chamfer not work?
Kevin,
I assume what you are making is what the picture is which is an 8 pin dip chip.
It should pattern and mirror. Are you using a conventional chamfer? Meaning not
surface to surface or variable. Those wont mirror or pattern as nicely.
