I imported some files and the sketch is in construction lines format, is there a way I can extrude without changing all to sketch lines, tks
No.
Either change all lines to solid, or start new sketch and convert the entities.
Arun,
Unfortunately there isn't a way. All you have to do is select all of the lines and in the property manager
uncheck the "For Construction" selection and you will be fine.
Thanks, worked!
Awesome, cool. Glad it worked out for you.
Arun,
