Solidworks crashes after using the following function.
This occurs when a drawing is already open. I am using this function to browse to ".txt" documents for defaults used in my macro. A single use of this dialog might be OK but when used twice or more it definately causes a crash after the macro has finished running. It is not always immediate but it crashes within 30 seconds or when I close the current Drawing Document. Any ideas?
Private Function funOpenFile(ByRef PathFile As String, ByVal sFileExtension As String) As Boolean
Dim PathOnly As String = PathFile
' Test supplied initial path
If Trim(PathOnly).Length <> 0 Then
' Test if path or file
Dim fa As System.IO.FileAttributes = System.IO.File.GetAttributes(PathOnly)
If (fa And FileAttributes.Directory) <> FileAttributes.Directory Then
PathOnly = System.IO.Path.GetDirectoryName(PathOnly)
fa = Nothing
' Test if the path exists
If Not Directory.Exists(System.IO.Path.GetDirectoryName(PathOnly)) Then
PathOnly = System.Environment.GetFolderPath( _
System.Environment.SpecialFolder.Desktop)
Else
' Show OpenFileDialog
Dim OpenFileDialog1 As New OpenFileDialog
OpenFileDialog1.RestoreDirectory = True
With OpenFileDialog1
.InitialDirectory = PathOnly
.Multiselect = False
.Title = "Select Preferance File"
.Filter = "Preferance file (*" & sFileExtension & ")|*" & sFileExtension
.FilterIndex = 1
.ReadOnlyChecked = True
End With
' Check to make sure the user selected a file and didn't click cancel.
If OpenFileDialog1.ShowDialog = System.Windows.Forms.DialogResult.OK Then
If String.Compare(System.IO.Path.GetExtension( _
OpenFileDialog1.FileName), sFileExtension, ignoreCase:=True) = 0 Then
PathFile = OpenFileDialog1.FileName
Return True
Else
Return False
Else
Return False
End Function
