Is there a code to put in the custom proprities value box that will pull the sheet metal thickness automatically?
Where do I find the list of codes SW uses?
"Thickness@Sheet-Metal1". This should get the thickness property provided you have a sheet metal part and the first feature name is Sheet-Metal1.
You can also use the Thickness from the value drop down list in the custom properties.
