Imagine I have a large (square-ish) galvanized bolt together tank...it has many seams that run its entire length and need a consistent bolt pattern. SW has lots of nice options to add in bolts/holes in at the assembly level and propagate to the part level, but you think they would give you an option to add in a linear pattern...after all bolts usually exist in patterns.
Basically what I am looking for is a feature that (at the assembly level) allows me to sketch a circle somewhere on a sheet, pattern that circle along a seam (and several sheets), cut that pattern and propagate it to all affected parts.
Options I have looked at:
Hole wizard - allows you to create either a 2d or 3d sketch to specify points where your holes will exist. It is impossible to make a pattern within a 3d sketch which renders that option useless unless I want to dimension 1000 points in a 3d sketch. For some odd reason the 2d sketch seems like it should have the functionality I need and works fine up until I add in a linear sketch pattern. As soon as that happens the propagated feature at the part level starts producing errors and it seems like the derived sketch is empty.
Extruded cut at the assembly level - same thing as the hole wizard.
Converting sketch entities to each part individually - far too tedius
Does anyone have any idea if this basic concept has been incorporated into some hidden feature I am not finding?
from the help file
Hole Series
You can use hole series to create a series of holes through the individual parts of an assembly.
The hole series is an assembly feature which creates hole features in the components of the assembly. You can create new holes or use existing holes. A hole series extends through each unsuppressed component in the assembly that intersects the axis of the hole (the components do not have to touch). You can specify the end of the hole series under End Component in the Hole Series (Last Part) PropertyManager. Unlike other assembly features, the holes are contained in the individual parts as externally referenced features. If you edit a hole series within an assembly, the individual parts are modified.
To create a hole series:
Suppress the components in your assembly that you do not want to be cut by the hole.
Click Hole Series
(Features toolbar) or Insert, Assembly Feature, Hole, Hole Series.
The Hole Position PropertyManager appears.
Select a location, which appears as a sketch point, on a planar face for the center of the hole series.
Set the PropertyManager options for the hole series by selecting tabs.
The tabs are always visible and you can select them in any order.
Click
NOTES:
If you add new components between the start and end components after you create the hole series, you can choose to include the new components in the hole series. You must edit the hole series to update it.
The depth of each hole within each component is measured from the entry face of the component to the end of the hole in the component. The depth displayed represents the actual depth of the hole in each component, resulting in accurate production drawings.
Hole series previews specify individual components of the hole series. Smart Fastener components also highlight. For example, when focus is on the Last Part tab, the last part highlights in the graphics area.
You cannot use hole series on assembly components which are multiple instances of the same part, unless each instance is a separate configuration of the part.
You cannot edit the parameters of a hole series hole in an individual part (unless you underive the feature). However, you can delete or suppress the hole. To edit the parameters of the hole in context of the assembly, go to the assembly and edit the hole series.
If you underive the hole series hole in an individual part it becomes a Hole Wizard hole with no reference to the assembly.
You cannot create a hole series feature containing holes that affect different stacks of components. For example, two separate hole series features are required to define the holes in this assembly:
Provide feedback on this topic
SolidWorks welcomes your feedback concerning the presentation, accuracy, and thoroughness of the documentation. Use the form below to send your comments and suggestions about this topic directly to our documentation team. The documentation team cannot answer technical support questions. Click here for information about technical support.
* Required
We have detected you are using a browser version older than Internet Explorer 7. For optimized display, we suggest upgrading your browser to Internet Explorer 7 or newer.
Never show this message againWeb Help Content Version: SolidWorks 2010 SP04
This is a beta test of the Web-based help function for SolidWorks 2010. The topics within the Web-based help are not beta topics; they document SolidWorks 2010 SP04. At this stage, the more significant bugs and other defects in the Web-based help have been removed. It may still contain some minor defects, however, which your use of the Software and participation in this test program will help to uncover and correct. Accordingly, you may experience periodic lapses or errors in the functionality of the Web help navigation and search or delays or interruptions in its performance. These are the normal and ordinary features of a beta test and shall not under any circumstances give rise to any liability on the part of DS SolidWorks or its licensors.
To disable Web help from within SolidWorks and use local help instead (similar to SolidWorks 2009 and previous versions), click Help > Use SolidWorks Web Help.
To report problems encountered with the Web help interface and search, contact your local support representative. To provide feedback on individual help topics, use the “Feedback on this topic” link on the individual topic page.
© 1995-2010 Dassault Systèmes. All rights reserved. | Terms of use
