Can someone step me thru createing this as a sheetmetal part? Never used sheetmetal before.
Hi Dave, 1. begin by starting new part, 2. then pick part, 3. next view right view. 4. Pick right plane, 4a. then pick sketch-line. 5. Draw profile of paddle. 6. Next dimension as shown. 7. You can align the end points vertically if you choose. 8. Pick Base Flange/Tab icon in the sheetmetal toolbar. 9. Direction 1 choose 18, 10. T1 = .03125 or whatever your thickness is, 11. radius is .03125. This will get you started. Thanks, Daniel
Thanks for all the replies. Now I need to add the holes, curved & radiused ends in the flat, how do I do that so it shows up in flat pattern & modeled versions?
Add the holes before you convert it to sheet metal, that will give you your holes in the flat pattern also.
Yes, you are starting in sheet metal. The two choices are 1. pick the surface the hole is to be placed in and create the hole then go to the next surface for the next hole, or 2. the better solution is to select a surface to remain flat and pick it, then use insert> sheetmetal> unfold to flatten the part. click select all bends. Now the part is in it's flat state and you can place the holes and radisus' with a cut or You can place the holes and use the fillet tool to radisus the corners. When finished with all cuts select insert> sheetmetel> fold and click select all bends. This will reform your part and the holes will be placed as needed.
If you try to just use a plane and sketch above the formed part for your cut, the holes will not be perpendicular to the face of the sheetmetel when flattened and thus may fail when flattened and will definitely not work for a CAM program.
Is it possible to draw all the detail in one sketch as a flat part, then bend? This way all the dimensions in the blank are what I want, the dimensions after bending are what they are.
Hi Dave yes, you'll then begin your sketch on the front plane. Extude it with a base flange/tab to the thickness you desire. Next on the top face of the part draw a line bisecting the paddle then pick the sketch bend icon and fill in the appropriate information, including the type of bend you'd like, radius and angle of the bend. Done. Thanks, Daniel
It's okay Dave, no, no extra steps or features are required. Simply pick either the face above the sketch bend line or the face below the sketch bend line. Thanks, Daniel
