im using solidworks 2010 and i need to put an emboss feature on a radius part does anyone know how to get this done thanks
I have to admit - I did not notice this was in sheetmetal. we don't use it much here, and I don't think I ever used an emboss from the design library - sorry.
that said, my understanding is that anything that bends or stretches in mor than one direction SolidWorks cannot flatten. so I doubt you will be able to get the boss to show in the flat state.
yea sorry i forgot to mension it was sheet metal but yea i have a radius im trying to put them on but they would only be bending in one direction you would im suprised that im not able to do an emboss on a radius and show it in the flat state if you know of anyother suguestions or know of someone else that might please send it/them my way
there are two different ways one way is thru the design library there are forming tools to create countersink embosses in sheet metal the way i did those on that part was i created at sketch and then used the wrap feature to get it around the radius and did that three times for the emboss and the hole and then the deboss features tho i am still needing to figure out how to get those embosses in the flat
I had no luck, I tried everything I could think of. At this point I'm not sure this is possible. Here's an interesting error message "
Following feature(s) were lost while folding/unfolding bend(s). Currently only simple through holes are supported inside a bend region:circular emboss9". From the looks of it, only holes would work. You would think a simple operation like this would be supported. Maybe I'm wrong and someone else here could shed some light on the subject. Sorry I couldn't help.
The file I attached was a simple hole just to show you but it could be done with other features, it would just take a bit more work. I used the Curve Driven Pattern. You just have to be real careful about how you setup your feature and what your selections are. For instance for the hole end condition i selected To Next. If i get a chance i will try to replicate the emboss.
