Hi!
I am automating aa assembly through an excel sheet.
The system is more or less like this:
the values are inserted into cells that are linked to dimensions from a sketch.
At the end there is a command button that rebuilds the whole assembly according to the dimensions entered.
This whole system is done using vba code.
my question is whether if it is possible to create a line of code to change the part configuration according to the value entered in the cell.
Ex:
part1 has 3 configurations
part 2 has 2 configurations
cell B3 - config3 (part1)
cell F4 - config 2 (part2)
Assembly - part3 (config1) + part2 (config2)
I hope you understand my explanation and my question
the sytax is this:
$configuration@component_name<instance>
here is the help on all DT parameters: http://help.solidworks.com/2010/english/SolidWorks/sldworks/LegacyHelp/Sldworks/Configuration/Summary_of_Design_Table_Parameters.htm
