Whether I here can use such wire (that is wire assemblage) in routing?
That is I should draw not only assemblage of a wire but also that he participated in routing
Sorry didn't understood you clearly but what I understand is that you looking to use your customized wires. If it is so, then yes provided you will have model them and place them under proper file location (look for the SW tutorial or help on routing)
"Sorry for my english" ©
Yes Deepak, all of you have correctly understood.
Whether but there will be a wire together with sockets flexible in assembly routing?
It will be as a wire or simple subassembly?
The best book on Piping & Tubing Design I had read, is from Wes Mosier but I don't know if it is still available.
Here is guide shared by Tom ( )
And you may also contact your VAR if you like to purchase the SW Routing Training manual.
Check here for training course on SolidWorks Routing
You can also check the videos available on YouTube on SW Routing
Check the Routing in SW online help.
I'm very grateful to you Deepak. It's really simple, but not for this:
How to create cable, wire, looms, braids with my geometry - like this https://forum.solidworks.com/message/122724#122724 (black spiral)
Another source for FABULOUS tutorials is investing into SolidProfessor's videos! We got tired of bad and very expensive instructions from our local VAR. So we invested into SolidProfessor! This 3rd party software can run inside SolidWorks as an Add-in. You can then do a "search" for a specific topic within SolidWorks when needed and it will find all the videos to play. Or this can run as a seperate application on your desktop! We absolutely LOVE IT! It's a HUGE time-saver and your skills will increase rapidly and expoentially! No more reading SW help files - for the most part!
I'm not here to endorse them, but to share my experience and likeness for this wonderful 3rd party tutorial for SolidWorks. This company also has TONS of files to download so that you can follow along in their video examples. In about 1 week, I had routing (which I knew nothing about prior) under my belt and felt confident in my new routing abilities, PLUS, know how to set-up and customize the libraries for wires/cables and components without difficulty!
They have four different packages to choose from. We bought the best - Premium package for $799/per seat. They will also work with you to customize a package for you, if needed. I can't say enough about them! http://www.solidprofessor.com/
Hope this helps!
Jay
