I'm trying to drop some decals onto some water tank equipment to pretty it up a bit and I've noticed after I've dropped the decal nicely onto the surface I'm getting a sliver of a decal artifact on the backside of my tank. What must I do to correct this issue?
-Mac
Nothing. . . . . .I fake it by using the offset surface feature. Slightly offset the surface that has the artifact and apply the same appearance to it. If the cylinder is one continuous surface, split the front and back and only offset the back. If you are using a transparent appearance, then you're outtaluck
Ryan
