ı am trying to import .step (a PCB) file into solidworks. The thickness of my PCB is 1.6 mm but when I import the file, it becomes 0,4 mm in solidworks.
Thanks for attention.
Astik,
I tried importing this and the results I got were the first time I imported it the thickness came
in .016 in. Then I did it a second time except this time I went to the Options in the opening
and selected under unit "Document template specified unit"
and it came up 4mm like yours did. Not knowing where you got this file, I would say on that end they need to check the option
settings to make sure something isn't scewing things on that end.
While importing, just check the units.
