I DO FOR HARD STEEL PIPING MODEL. IT DOESN'T SUPPORT TO CHANGE FLANGE AUTOMATICALLY WHILE CHANGING PIPING DIAMETER.
I WANT TO CHANGE FLANGE'S TYPE FROM RFSO TO RFWN WHEN ITS PIPING DIAMETER FROM 1" TO 2"
IT DOESN'T SUPPORT AUTOMATICALLY, I HAVE TO MANUAL CHANGE IT ONE FLANGE BY ONE FLANGE.
THE WORSE IS THAT, I CAN'T CHANGE THE FIRST FITTING(FLANGE) FREE.
DO YOU HAVE OTHER METHODS TO COMPLETE THIS?
THANKS.
Hi ginqhai,
Use the Change Route diameter function to change the diameter. On this dialog there iks a browse buttonfor each end fitting. Use this to browse to select a different fpart for the fitting.
You can see the Browse... buttons in the attached image.
Best regards
Andy
