i'm new to solidworks motion, could someone please guide me how to mate a shaft which carries eccentric loads to get correct reaction forces and moments on its bearings? also i want some information about bushings and how to use them to manually remove redundant constraints.
thanks in advance.
split the shaft face so you get appropriate areas for the bearing areas, put coordinate systems at the centers of the shaft in the mid planes of the bearings, use the remote load rigid connection to apply the restraints, constrain as required. Take the torque out somewhere other than the bearings.
