I can not seem to get the command to work. I pick the item I want to copy with mates and the mates appear. I check the OK and nothing. How do you use this command. I looked at the help and it does not seem to function the way it expains it.
Once you have chosen the piece to copy all mates relating to that piece will appear. You can then choose which of those mates to copy. Once you have the mates you do want to copy you must select the box next to the mate so that it is highlighted and then go into the assembly and choose the geometry you want to be the other half of that mate. So if you are copying a nut with mates you would choose which mates to copy and then if the first mate is a concentric you would select the box next to the concentric mate and then go into your assembly and choose a hole or something for that concentric mate on the nut to mate with.
Ryan W.
