When creating an electrical route by a From/To list the wire geometry is not created. The result is a 3D sketch without any solid wire geometry. Does anyone have a fix for this?
There isn't much info to go on here. Have all the wires been routed - use Edit wires and make sure every wire has a path through the model. Check for bend radius errors. If the bend radius is too tight we don't create the route geometry so you can easily see where there are problems.
Hi Chris,
Cheers
Andy
