I am designing a Fixture for a co-workers assembly and getting messages I am not used to. Can someone please clarify. The messages are as folllows, when I try to save my file for the first time, the choices are do I want to save "Read Only Doc's" which in this case is his Main Assy that is in use by him. When I select the "Do not Save Read Only Button" Then I'm getting a question if I want to save "Internally to the assembly, or Externally. Can someone please explain/advise -Thanks
Hi Raymond my guess would be either you have incontext or parts created within an assembly and it wants to know if you want those internally created parts or incontext info to be saved internally within the fixture you're creating or externally as separate parts.
Or it may wanting to know if you wish the fixture you're creating to be saved internally in your co-workers assembly or externally as a separate part/subassembly.
Thanks, Daniel
