I have sheet metal part file and would like to make flat pattern for the existing sheet metal part file.
See attached file.
When click "Flatten" button it is apear a message with error.
Can anobody tell me what I should make in order to make Flatten?
Thanks in advance!
Hi zdrako,
I am guessing the error message will be to do with the 2 flanges on the inside of the "L" shape overlaping.
You would not be able to make this in a single part using standard sheetmetal tooling, the part would have to be pressed into that shape if you require it as a single part.
Michael
Edit:- If i was making the part I would just make a square corner and have the welder do a fillet weld in the corner
