Questions
1) I have the PDMW set up at the minute just testing it and at the moment if i check out a file to work on. Other Users (mainly read only) need to be able to View and print the Last approved version to work to.
2) Im having trouble setting up the Revision to work properly. currently everytime it just checks in the revision Ticks over. How do i set it up so we have a "desgin" revision IE Pre Realise.
Info that might help is that i have my Access Controlled via Life cycle Release,Underchange,Underreview and Approved.
Thanks In Advance
Joe
I think you just do this through lifecycle.
Set those that are read only to only be able to view the lifecycle "Approved".
When a job is is design or changes, then won't be able to see it because the lifecycle will be in a different state.
