I noticed a change in functionality from 2009 to 2010 with regards to the underlined letters Alt shortcuts. I used to be able to prompt the Insert Component function with a keyboard shortcut, then open the Browse with a simple Alt+B. Now I've got to go change the focus to not just the Insert Component Property Management tab, but the Part/Assembly to Insert sub-menu. What's the point of having underlined letters if you basically have to click on the option anyway?
It appears that Solidworks has decided to keep the focus on the part/assembly even when you select a new Insert command (whether that's a new component, pattern, table, geometry).
This is definitely a change from 2009 to 2010. Any way to get this back?
Interesting. I am seeing the same behavior. I typically expect the feature manager to take the focus when it is initiated, so I would call this a bug.
