I encountered some "Imported"parts indicating an error propagating through my assemblies, and when back to the part all I have is an imported part with an yellow icone exclamation mark indicating an error ...all I could do was check the part itself with the functionality under TOOLS > CHECK ... So I run and was given the faces that had a problem ..It did show a window "Check Entity" and running Check I got a result List only.but not the solution for fixing it ...Doe any body knows how to fix using other advanced techniques or SW tools ?
NOTE:
1. Also I had the bottom box in the WINDOW "Check Entity" teeling me " 4 general fault(s) found. No Invalid edges/faces found.
2. At the result List i got: Face-face inconsistent 4x.
Thank you,
Robert Cruz
