Hello All,
I want to know how to store Part No. and Description of a model so that it is diplayed in a BOM in an assembly and at the same time displayed in Vault View in Workgroup PDM.
Also, I am unable to set the Vault View to display Custom Property. Some of the toolbox files are checked in the vault and the descriptions are not displayed
Thanks you for your help.
Well, if would appear as if your "Description" property is empty. And make sure a configuration specific property called "Description" doesn't exist unless you know what you're doing and using it. Also please change your "Number" property to "Material."
As far as your toolbox parts not showing their description; you may have ONE document checked in with MULTIPLE configs, which Description should PDM show you? I believe it will display near the Link of a toolbox part which specifies the configuration to use.
