Hi.
I have i part. I wan't to insert a designtabel. Now I have some problems.
I have worked on the part, and applied a desingtabel. It is set to automatical add new dimensions.
Now I miss some dimension in the tabel. They will not appier automaticaly then i edit the designtabel.
I have tried to delete the tabel, and make a new, but it seems that SW remember the deminsions that once have been added.
Is there a way to "reset" the designtabel, so all dimension is scaned again.
I realy don't wan't to manualy copy/paste the names into the tabel for this part.
best regards
Jens
Welcome to SW forums Jens.
Edit you design table (DT), highlight the dimension you want to add to DT by clicking on the feature (this will add a feature state column which can be removed afterwards) and then double click on the dimension. It'll get added to the DT.
Also make sure you have selected "Show unselected dimensions again" in the Add Rows & Columns for DT.
