I have problem if I want to save just an assy, but no modified part or subassy. I tried to solve this with selecting Save as... . I choose same name of assy, after that a window appears and asks me to confirm, that all modified parts will be saved. If I press "No", nothig is saved, if I press "Yes", everythig listed is saved. There is really no possibility to save only the assembly? Same situation with part, which contain references to different parts. No possibility to save just the main part..
Thanks a lot
Radim
Welcome to SW forums Radim .
Assembly consists of parts and sub assy only. If you made changes to parts/sub assy then only you're making a change/modifying your assembly. Apart from that you can modify assembly via changing mates or adding/editing assembly based features. So what exactly your modifications in the assembly are??
