Hi all.
I often save out my flat sheetmetal patterns to DXF format.
I have used a couple of different methods....usually RMB flat pattern in the feature manager tree, or if it is a part that has no sheetmetal feature, I save it via a blank drawing template and save as DXF.
This was all fine with SW 2009, but now after recently installing SW 2010, I cannot save with an output scale of 1:1 when I save directly from a flat pattern.
In the window that comes up in options when I hit save, the output scale 1:1 option is greyed out.
However, if I save it via my blank template method, the option is alive and well.
I have tried searching on this forum, but can't seem to find any other problems similar.
Any ideas? Am I missing something simple?
I have tried repairing my installation, but no luck. I am using SW2010 sp0 as this is as far as our company subscription has reached.
Thank you for any input.
Andrew,
I beleive the option is greyed out is because it will automatically output a 1:1 scale dxf from a model. Give it a try and confirm that it is truely 1:1 output.
Cheers,
Anna
