Ok.. I underway with learning all about PDM thanks to Ken :thumbsup:
I've entered a few test projects on a local vault. But what I've noticed straight away is that all projects and sub-projects appear in one long list??
So... If you go to check in a new project... You have the project "folder" in place on PDM.. On the check in page, I select what project I'm checking into..
Now when I have 2000 + jobs on the system, and projects holding all the standard common files etc. I will have a huge list? no tree funcionalty at all?
I have to pick which project I'm checking into from one long long list?
Doesn't anyone find this a bit archaic or am I missing a stupidly simply workaround?
Trev
Trev,
Often I feel PDMWorks has a very archaic feel, but with focus almost exclusively on Enterprise, I guess that is too be expected.
However, one thing you can do to help your situation a bit is to pre-select the folder you want to check into before hitting the check in button. This way you do not have to sift through the long tree to select the folder you want.
Aaron
