I seem to be unable to get Soldworks to produce certain kinds of plots for the simulation results. These specifically are the rotation and moment plots that should be a subset of the "Displacement" type plot. I have tried setting the default plot options in the Simulation>Options>Default Options box/tab and in there I can tell it to produce default plots with any of the X-Y-Z-Res displacement/ X-Y-Z-Res rotation/ X-Y-Z-Res moment/X-Y-Z-Res reaction force options. However when running the simulation, only the resultant displacement plot shows up. When I try to manually define/create a new plot by right clicking on the results folder in the simulation "tree" it only gives me options to select X-Y-Z-Resdisplacement and X-Y-Z-Resreaction force. Can anyone tell me what might be going on?
Running SW2010 Premium 64bit with Sim Pro on win XP 64
-Mike
Hi Mike,
The reason you cannot select those Displacement Results is probably because of the Simulation type you are running. The ones you are referring to are only available for Shell, Beam and Mixed Mesh Studies.
Ryan W.
