I am continuing to fight with this imported surfacing project. I have an imported surface model of a fiberglass part. I am currently attempting to remove the trim flange on the outer edge of the part as shown below.
Weather I select one face or the whole outer flange and attempt to delete it I recieve rebuild errors that this would create a vertex with more than two converging open edges. I have selected several different faces to delete with the same results. Can someone explane this to me so i have a better idea of how to solve this problem?
thank you
Jim
Hi Jim,
You've got lots of other problems with your Surface-import417 that preclude you from using features like Delete Face. Go to Tools/Check and uncheck "Solids" and then cleck "Check." Notice that there are a number of inconsistent faces in your model. You need to go back to the original import file and work on getting it corrected before building features on the surface body. Check out my blog post - it might help.
Regards
Mark
