Is there a tool bar or some thing that I can turn on that holds the last 10 or so commands for easy re use?
Some cad software’s call them "most recently used list" or MRU.
Does Solidworks have this feature and if so where do you turn it on at?
Hello Mr. Doe,
Yes, there is such a feature. Simply right click (whether in a drawing or part/assembly), and one of the options should be "recent commands".
Similarly you can populate the "S" key with what you commonly use. The image below shows my current configuration for parts and sketches. I hope this helps.
Rob Stupplebeen
Hello Mr. Doe,
