I've been frustarated with my system from day 1. I average about 2 SW crashes per day and its slow all the time. Most assemblies are small 10-50 parts. Might see 200 max. I've had my system "rebuilt" - OS re-installed by our IT department and I've installed and re-installed SW a few times. I'm trying to get approval for a new machine, but we lease Dell's and I maybe stuck with it for another 18 months. I don't have any issues with other programs crashing.
My specs are as follows:
Dell T7400
Windows XP SP 3
SW 2010 SP2.1
Dual E4505 Xeon processors (2.0 GHz)
4 Gb RAM
Nvidia Quadro FX 3700
My company is hessitant to go to 64 bit. Is that what I need along with more ram?
Your computer is always going to be slow. 2 cpu's at the slowest clock speed is not a good configuration for speed in SolidWorks. You are better off with a single high Ghz CPU. Something in the 3 Ghz or above range. I would see about replacing your CPU with a single CPU of high clock speed. It can be multiple cores, needs to be a much higher clock speed. Do you have an approved video card driver for your system, running SW2010? To give you an idea of where your computer stands for speed check out the benchmarks I have on my website in the right sidebar. www.solidmuse.com. The punch holder benchmark has a Google spreadsheet of results for several hundred systems. You really have spent a ton of money on a system that is spec'ed wrong for the type of work you do. Unless, the Dell guys gave you a great deal on what you thought was a hot system. Dell does that when they are clearing out old stock. Many buyers get burned by this.
