I am trying to create a smart component, containing (2) nuts, (2) flat washers and a roller. I am building a roller conveyer. I want to coincident the roller assembly onto the legs of a (2) channels, there are (69) rollers required. I tried to make smart the shaft diameter and a hole in the channel leg a concentric mate and one of the faces on the washer to be coincident to the channel leg.
Does anyone have a suggestion? I have attached the components.
I understand that you need to have all objects independent.
So another option may be useful for you.
This is a "Copy with Mates"
In this case concetric mate leave as is, and coincident select repeate.
Click on a hole where you want the next component, and press enter. and go to the next hole
