I am working through the trebuchet and when I get to the part where you insert the catapult base assembly and it does not show up. It says to attach it to the origin, but the origin does not show up. It does not appear on the screen at all . Is there something that I am missing?
I have no idea what trebuchet is, but i assume it is some sort of assembly. I am also assumming that you are trying to bring in a part and or (assembly of parts) into a larger assembly. If all the parts are oriented and built from the same orgin, you can simply click ok when bringing in. Or you can go under view then click the orgins buttion to display orgins. then manually bring the part and move it as you are bringing it in until the orgins go over top of one another. Dont know if this helps.
