how can I fix this cross section problem in assembly drawing?
thanks.
thanks.
Thanks for your reply, but I'm not sure to understand your reply,
I'm new in solidworks and i came from Autocad, corret visualization is like attached photo,
How I can obtain same visualization? I' using cosmetic thread.
what do you mean "over complete length"
piece is 10mm long and thread is 5mm, if thread is longer as complete piece result is same.
If the threads are not on the full length, then how come you'll have that in drawing.
Can you upload the all the files here to check.
probably you are non understood my question, my complain is that solidworks overlapping filled lines, not lenght of the thread, see atteched.
I don't think that you can get that kind of result with SolidWorks or any similar 3d cad software. In AutoCAD, it is doable because we are making it manually but in 3d cad software, this is how it has been programmed.
So, you are saying that this result is better that solidworks can do?
Uhmm. I' m surprise but if there is no way I accept,
thank you very much for you help.
Marco,
I am sorry to say, but yes, that is what you should expect. Solidworks doesn't much care about creating real/correct/standard/accepted 2-D drawings.
It is a shame, but you will have to down grade your expectations.
It is a strong 3-D modeling system, weak on the 2-D side.
reagrds,
Alan
Thanks Alan,
I agree with you, it's a shame to down grade instead of increasing quality, my drawings will seems less professional than now.
Why is that a problem? Considering the actual thread profiles are not being shown, it shows the effective condition in that area.
Changing the orientation and scale of one of the hatches might minimise the visual impact.
