When doing a flat pattern in lofted bend sheet metal part how do you get just one bend line for the bends. for instance we are doing a gutter system that has a 1/8" drop in the center every foot. The gutter is 36" wide with sides and a lip on both sides. see attached file
Thank you
Not 100% sure what you're asking for here. Your part, and it's flat pattern look correct. The double line you see is because there are two bends close together to allow for the compound angle.
