Hello All,
I am running SW 2010 sp3.1 on a 64bit windows 7 system today. I am trying to make a weldment of a steel cage for some subsea equipment that requires some 1" round bar be bend at 60 deg to taper into another section of the cage. Admittedly I don't work with weldments everyday but I used to do this in the past for sure in 2009 and earlier versions
1. Draw two lines with an angle of 60 degrees
2. Add a sketch fillet of any value between the lines
3. Then select all three segments and create a fit spline
4. Use the fit spline as a path for the weldment structural member.
When I try this in 2010 it won't even select the fit spline. If I remove the fit spline I then need to select all three segments individually and it gives me three seperate solid bodies; obviously not what I need.
Has anyone else run into this?
It turns out you cannot use a fit spline or any spline for that matter in a weldment structural member path.....did I mention I don't use weldments much? ;-)
I found this in the KB, I must have been using a sweep back then and didn't remember correctly. I did submit an ER though under WELDMENTS>STRUCTURAL MEMBERS and used works like "fit spline" and "weldment" in my description in case anyone else would find this useful.
