Hi
I have designed a assembly which has let's say for example a square cut out one side and a circle cut out on the other side.
Each cut out has a separate cover (1 square , 1 round)
I have set up various configurations of this, but what I want the design table to do is:
If I suppress the square cut out I want the square cover to suppress automatically.
I think the only way to do this is by using a formula in excel something like=If A1 is suppressed then B1 is also suppressed, but how do I write this as a formula?
Or am I making this to complicated, could there have been something I could have done in the actual assembly?
Thanks in advance
Tom
Tom,
It seems like this would be really simple. As I recall, the suppression state is set by an S in a column. If that is so, I think you just need to set the value in the cover column to equal the value in the cut column.
Jerry Steiger
