ive been trying to mesh @0.9mm in solidworks simulation 2010 but the system is not able to process the meshing and analysis . but the analysis works fine if the mesh size is above 3mm.
Is it a problem with solidworks or is it the system cannot handle it ?
We are using it on a hp x4300 workstation. (dual core ,4GB ram and 256MB nvidia graphics card)
Should i go for a better system or is it ok to upgrade the present one.
venky.
Try meshing smaller than 1mm on on sample/simple plate and check. I believe you need more better machine as the number of nodes might be increasing and your present machine is not capable of taking it up. Better to go on 64 bit machine and ass RAM.
